[mapguide-internals] Sheboygan package
Tom Fukushima tom.fukushima at autodesk.com
Mon Sep 15 17:46:46 EDT 2008
Hi Sergi,
In order to fix the FF3 problem you should get the latest source.
For the other problems, I wonder if you have the wrong version of PHP installed. It needs to be PHP 5.2.5.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of sergi nistal
Sent: Monday, September 15, 2008 4:34 AM
To: mapguide-internals at lists.osgeo.org
Subject: FW: [mapguide-internals] Sheboygan package
Hi, firts I´m sorry for so many mails. The problem was that I used FireFox3.Now I have other problems:1- The result of the image 'mapagent1.jpg' is 'mapagent2.jpg', it´s ok (argument out of range)?2- Warning in 'find address' (image with the same name). It works but it returns this warning:Warning:Call-timepass-by-reference has been deprecated; If you would like topass it byreference, modify the declaration of xml_set_object(). Ifyou would liketo enable call-time pass-by-reference, you cansetallow_call_time_pass_reference to true in your INI fileinC:\MAPGUIDE2\mapguide-2.0.1\Web\src\phpviewersample\findaddress\kd_xmlrpc.phponline 83 (and other lines)3- Problem in 'query features'. Image 'query features1.jpg'. In the box 'Layer' only appears '>', in the box 'Property' appears nothing, ...4- The same problem that 3 in 'theme player'.5- To use 'plot as DWF' I need Autodesk DWF Viewer, don´t?Thanks.
_________________________________________________________________
Prueba los prototipos de los últimos en MSN Motor
http://motor.es.msn.com/
More information about the mapguide-internals mailing list
