[mapguide-internals] MapGuide Open Source 2.0.2 posted
Zac Spitzer zac.spitzer at gmail.com
Tue Sep 16 05:02:17 EDT 2008
I did manage to get the mapguide server completely stuck with GDAL,
tho i think it's slightly
more stable than before
z
On Tue, Sep 16, 2008 at 6:51 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Looks really good so far, I have successfully seeded an entire map on xp using
> managed sdfs without the server falling over or producing a single
> error :) 30k tiles
> The memory usage hovered around 60-63 mb, whereas with 2.0.1 it would
> blow out to 600mb+ before crashing..
> I did make two tweaks to the standard config before i tested which where
> CacheSize                          = 1000 (was 100)
> #DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
> I quickly tried out a GDAL raster layer and it also just worked
> without any errors
> Regards
> Zac
> On Tue, Sep 16, 2008 at 5:00 PM, Tom Fukushima
> <tom.fukushima at autodesk.com> wrote:
>> To MapGuide Internals,
>> The MapGuide Open Source 2.0.2 candidate installers and tar file have been posted to http://download.osgeo.org/mapguide/releases/2.0.2/.  Give it a try if you can before we formally announce it.
>> Thanks
>> Tom
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
