[mapguide-internals] RE: PATCH: Raster stability fixes, ticket #462
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Apr 2 04:38:53 EDT 2009
After testing the Dll's provided by Haris/Jason, I finally have a stable
MapGuide solution, so a BIG thank you for that!
Next stop is faster rasters. Would it be possible to produce compiled
dll's for testing the solution that Traian proposes,
and post them somewhere? I can host them if that is the blocker.
Regards, Kenneth Skovhede, GEOGRAF A/S
Traian Stanev skrev:
> I attached a new patch for the provider to the ticket 462, which speeds up GDAL FDO connection opening by 95%, in addition to the refcounting fix, and the global mutex removal. The global mutex is still needed in two places where I did not disable it.
> This change allows you to completely disable MG connection pooling for the GDAL provider (like for SHP and SDF) and still have very good raster speed, since opening a connection is fast now. Also, the global raster mutex can be removed from the MG code.
> I will continue testing with this configuration, but so far it looks stable and fast. Obviously it is impossible to prove that a problem no longer exists, when threads are involved, but I will throw some more difficult tests at it -- so far I have only tested with a TIFF-based layer only. The TIFF is 450 megs or so.
> Traian
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
>> internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
>> Sent: Sunday, March 29, 2009 1:29 AM
>> To: MapGuide Internals Mail List
>> Cc: FDO Internals Mail List
>> Subject: RE: [mapguide-internals] RE: PATCH: Raster stability fixes,
>> ticket #462
>> I attached the patch for the GDAL provider to ticket 462.
>> Traian
>>> Sent: Sunday, March 29, 2009 1:22 AM
>>> ticket #462
>>> For what it's worth, patching the provider to addref the parent
>>> connection from the feature reader fixes the problem. This is on top
>> of
>>> Friday's trunk MapGuide and FDO code, without any other extra fixes.
>> I
>>> do think it is a bug not to addref the connection from the reader,
>> when
>>> it in fact depends on it to be alive, in order to get stuff from it
>> at
>>> a later time.
>>> I am pretty sure the addref fixes the problem, because the test I am
>>> using is fairly brutal and produces the crash/deadlock in less than 5
>>> seconds every time I run it with unpatched GDAL provider. With the
>>> change, I ran it multiple times to completion.
>>> I am unhappy with the fix though, because it leaves CPU usage by
>>> mgserver at ~5%, even though I am doing something like 16
>> simultaneous
>>> requests... So then I decided to remove the global mutex from inside
>>> the provider -- that didn't make a difference in CPU usage, and the
>>> test still passed without problems. So that mutex can go. Then I
>> messed
>>> with the connection pooling settings in serverconfig.ini -- those
>>> didn't make any difference. I tried them all for the GDAL provider
>> and
>>> the test still passed with 5% CPU usage. I don't think the process is
>>> blocked for I/O because the TIFF I am using is not huge and I also
>>> generated an overlay pyramid (which I highly recommend to anyone by
>> the
>>> way, it makes a huge performance difference for TIFFs).
>>> Traian
>>>> internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
>>>> Sent: Saturday, March 28, 2009 4:43 AM
>>>> ticket #462
>>>> Regarding MG raster problems ( or any other provider ) the main
>>> reason
>>>> is connection manager.
>>>> If you would set connection pool size 1 , for sdf provider MG will
>>> not
>>>> work properly.
>>>> The patch Jason submitted, is workaround for issue. It will not
>> cause
>>>> GDAL to work slower, because provider itself is basically
>>>> single-threaded now.
>>>> That was done trough work we were doing years or so ago. I was
>>> looking
>>>> at provider back then and realized that making gdal calls guarded
>>> will
>>>> make it more stable. Frank then submitted patch with guard on every
>>>> single gdal library call.
>>>> I will try to explain what is happing now:
>>>> 1. Map with more than one gdal layer
>>>> 2. There are two calls in server code execute query and stylize 3.
>>> One
>>>> thread will open connection in execute query and went to stylize
>>>> procedure 4. Another thread will come into execute query and
>> because
>>>> it could be another layer it will try to open new connection 5.
>>>> Connection manager will check pool size ( 1 in gdal case ) and
>>> because
>>>> provider didn't inc. reference count to connection (not  way to
>> solve,
>>>> but anyhow provider needs to increment ) it will delete previous
>>>> connection and create new one 6. Access violation in first thread
>>>> while stylization because of deleted connection
>>>> In shorter version things to change:
>>>> 1. FDO GDAL provider is not increasing reference count on FDO
>>>> connection when used in other classes like georasterband , which is
>>>> later used in query (wrong) 2. connection manager is managing
>>>> connection pool by using fdo connection reference count ( wrong ) 3.
>>>> it looks like working for other providers, because connection pool
>>>> size is 200 and other providers are incrementing connection pointer
>>> in
>>>> select command for example, but if there would be provider with
>>> select
>>>> command with no reference count to connection, it will crash too 4.
>>>> Server code is making assumption that pool size for single threaded
>>> is
>>>> 1 (not correct), we need to make code change to allow for making
>>> calls
>>>> to provider single threaded
>>>> Haris
>>>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
>>> Bruce
>>>> Dechant
>>>> Sent: Friday, March 27, 2009 4:55 PM
>>>> Subject: [mapguide-internals] RE: PATCH: Raster stability fixes,
>>>> ticket
>>>> #462
>>>> I totally agree - the locking needs to be in the provider.
>>>> Thanks,
>>>> Bruce
>>>> Traian Stanev
>>>> Sent: Friday, March 27, 2009 9:40 AM
>>>> ticket
>>>> #462
>>>> It does look like a sledgehammer approach -- what if some day there
>>> is
>>>> a raster provider that works ok and doesn't need the locks? If
>>>> anything, the lock should be in the FDO provider.
>>>> Traian
>> Walt
>>>> Welton-Lair
>>>> Sent: Friday, March 27, 2009 11:11 AM
>>>> ticket
>>>> #462
>>>> The memory patch (mapguide_raster_unalloc.5.patch) looks good, and
>>>> I'll submit that.
>>>> The stability patch (mapguide_raster_stability.patch) looks
>>>> reasonable, but I'd like another 1 or 2 people to also look at it.
>>>> It's significant since it limits MapGuide to processing one raster
>>>> stylization request at a time, but I guess that's better than
>> having
>>> a
>>>> dead lock.  Anyone know where the thread-unsafe code actually is?
>> Is
>>>> it in the provider itself?
>>>> Can the mutex be moved closer to the actual thread-unsafe code?
>>>> Walt
>>> Jason
>>>> Birch
>>>> Sent: Friday, March 27, 2009 3:10 AM
>>>> To: mapguide-internals at lists.osgeo.org
>>>> Subject: [mapguide-internals] PATCH: Raster stability fixes, ticket
>>>> #462
>>>> Hi,
>>>> Haris has been working on the raster stability problem against
>>>> MapGuide 2.0.2.  I was having the same problems, and was able to
>>>> duplicate on 2.1.  I have worked with Haris to create patches
>> against
>>>> trunk that address a couple of the problems and increase stability
>>> immensely.
>>>> Could someone please review the patches attached to:
>>>> http://trac.osgeo.org/mapguide/ticket/462
>>>> and commit them to trunk if appropriate?
>>>> My feeling is that the connection management stuff may need some
>>>> additional work, since limiting the connection pool to 1 for
>>>> single-threaded providers doesn't appear to have the desired effect.
>>>> However, getting both of these patches into 2.1 would at least
>>> improve
>>>> stability for Raster users.
>>>> Jason_______________________________________________
>>>> mapguide-internals mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
