[mapguide-internals] MGOS 2.1 Failed Install Notes
Jackie Ng jumpinjackie at gmail.com
Wed Apr 8 10:15:20 EDT 2009
does phpinfo() work for you?
Also if you set "display_errors = On" in php.ini, is there any extra error information?
- Jackie
I downloaded the 2.1 B installer...I ran the installer on an XP machine SP3, I had previously Uninstalled MG 2.01 and Web Extensions...
...Heres what I go...
In order to run the mapagent and enumerate resources I had to switch fcgi to use mapagent EXE before it would work...
...On Mapadmin I got the 500 error, I moved my PHP system Variable to the front of the line...and even rebooted No luck...i changed my PHP extension to use PHP-CGI.exe...I now get the login page...I login as I did succesfully on the mapagent Administrator/admin And It doesnt go to the 500 error page...It just Gives my a red "Authentication" Error msg...when I try to Login with a bad username and pass...I get an error saying bad user name and password...What gives?
I'm assuming this post belongs here since its Beta...and not full release.
View this message in context: http://n2.nabble.com/MGOS-2.1-Failed-Install-Notes-tp2605463p2605548.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
