[mapguide-internals] Installer progress
Jason Birch Jason.Birch at nanaimo.ca
Thu Apr 23 09:52:55 EDT 2009
Hi Gunter,
Did the service get installed at all?  Does it start after a reboot?
If it doesn't start, what happens when you start an elevated command prompt, navigate to MapGuide/Server/Bin and type "mgserver run" to start the service interactively?
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Thu Apr 23 03:30:59 2009
Subject: Re: [mapguide-internals] Installer progress
I've tested the installer on Windows Server 2008 and the installer seems to
put everything in the right place (.NET/IIS). IIS 7 integration also seems
OK (I could open the PHP MapGuide Admin), except that i'm not asked during
installtion which ApplicationPool to use (like under W2k3).
Unfortunately the MapGuide Server did not start. I'm not aware if this is an
installer issue or if this is caused by unsufficient privileges.
On W2K3 installtion works fine like Jason already mentioned. MapGuide Server
process is running.
Gunter
Jason Birch wrote:
> Well, I think I have the IIS7 installer working OK; I still have to test
> uninstall.  You can see the details here:
> http://trac.osgeo.org/mapguide/changeset/3834
> I've uploaded a new installer (that also includes Bruce's FDO connection
> manager fixes and Walt's rendering enhancements for those who are curious)
> to the following directory:
> http://download.osgeo.org/mapguide/testing/
> -or-
> ftp://download.osgeo.org/mapguide/testing/
> I haven't had a chance to test the Apache/Tomcat/IIS6 installers yet, nor
> on platforms other than W2k8, and it's quite possible that I broke
> something.  If you have a chance to install and report back on the wiki
> that would be great, otherwise I'll try to get some testing done on my VMs
> tomorrow night.
> http://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
> Jason
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2682181.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
