[mapguide-internals] Installer progress
alucas alucas at svl.es
Thu Apr 23 17:36:32 EDT 2009
Ok Jason,
Forget my last post. I've installed the 0.5 test version and as you say i
receive the error:
"The specified module could not be found"
After investigate some issues, my conclusion is that the problem is about
the paths for .fcgi and .php extensions in the mapguide virtual directory
configuration options.
If I try to specify the path between "", for example in spain:
"C:\Archivos de programa\OSGeo\MapGuide\Web\Php\phpisapi.dll"
the problem is not solved.
But, do this test. Copy all the content from the php directory for exmple
into c:\tmp (or some directory that you like) and modify in mapguide virtual
directory (IIS) the configuration of the extensions for .fcgi and .php, you
need to point for the two extensions to c:\tmp\phpisapi.dll (the key is that
this path does not have spaces) then the site administrator works well for
me.
Thanks.
Jason Birch wrote:
> I believe that I installed for IIS+PHP, but the problem is in the ISAPI
> extensions that get installed regardless of the viewer that is chosen (the
> MapAgent and PHP ISAPI handlers).
> Jason
> -----Original Message-----
> From: alucas
> Sent: April-23-09 9:31 AM
> Subject: Re: [mapguide-internals] Installer progress
> The problem is for IIS + PHP or IIS+ASP?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2686864.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
