[mapguide-internals] mgos installer question/comments
Paul Spencer pspencer at dmsolutions.ca
Wed Apr 29 12:12:41 EDT 2009
On 29-Apr-09, at 12:02 PM, Jason Birch wrote:
> Paul wrote:
>> question: why does the installer need 900+ MB on c:\ even
>> if you install elsewhere?
> I think it's an MSI thing; the bootstrapper expands one copy, and
> then msiexec creates a copy to install from.  But with TEMP re-
> pointed, maybe that's not the problem.
> Maybe we'll try exposing an InstallDir dialog earlier in the process
> and see if that helps... at this point I want to limit changes in
> the installer to fixing critical problems though, so this will
> likely have to wait for 2.2.
not a big deal, just wanted to let you know in case the installer was
doing something it shouldn't.  My VM is probably an extreme case.
>> installer tells me it is going to use over 900 MB on c:\ but after
>> install it has only used about 500MB
> On the C drive?  What's installed there?
I don't know - about 500 MB of 'stuff' somewhere, not sure where but
that's how much space I lost - actually, looking at it again its only
350 MB (only!) that is gone.  Its not installer stuff in the TEMP
directory so I really don't know what it installed.  .NET framework
stuff?
> After the first reboot?  The MapGuide service requires the
> MENTOR_DICTIONARY_FILES environmental variable, and this isn't
> available to the service account until after a reboot (because it's
> already logged in).  For 2.2, I we want to move to reading the
> default dictionary directory from serverconfig.ini and
> webconfig.ini.  There's already code in there to read from an ADSK-
> specific directory if the env var isn't set; this would just expose
> that directory as a configurable item.
um.  maybe I didn't reboot so lets say that is the problem :)  I don't
recall it asking me to reboot though - should it have?
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the mapguide-internals mailing list
