[mapguide-internals] new projection in csmap
Paul Spencer pspencer at dmsolutions.ca
Wed Apr 29 20:10:17 EDT 2009
Zak and I have it working now to specify a google layer and a mapguide
MapDefinition as an overlay in Fusion.  Instructions are being
prepared, we'll let you know as soon as its up (will require trunk
fusion because there were some necessary changes)
Cheers
Paul
On 29-Apr-09, at 5:27 PM, Jason Birch wrote:
> Yes... assuming that all of your existing data sources have
> coordinate systems defined, and that CS-Map is able to project
> between them and the popular vis CS.
> That's how the enterprise.mapguide.com example is doing it.  Their
> source data is the standard Sheboygan data in LL84.
> http://tinyurl.com/cy5wer  (MapDefinition - just use Anonymous user,
> no password)
> More info on the enterprise.mapguide.com implementation:
> http://n2.nabble.com/re%3A-flexible-web-layouts-tp2660073p2661342.html
> I tried getting a Google Maps layer to work by adding it to an
> ApplicationDefinition based on the info in the Mike's blog:
> http://research.dmsolutions.ca/?p=314
> But wasn't able to get both the MapGuide and Google Maps layers to
> initialize when part of the same map.  I actually prefer the MGE
> demo implementation because it also includes a Google layer-type
> switcher.  I could see extending this switcher to allow me to choose
> between Google layers and also MapGuide HTTP tile layers on all of
> my maps.
> Jason
> -----Original Message-----
> From: Paul Spencer
> Sent: Wednesday, April 29, 2009 2:04 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] new projection in csmap
> That works.  Should it work if I do that on a MapDefinition (will it
> convert all the layer definitions on the fly)?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
More information about the mapguide-internals mailing list
