[mapguide-internals] Re: RFC 71: Please review changes so far.
Christine Bao Christine.Bao at autodesk.com
Fri Aug 7 05:34:44 EDT 2009
Hi Jackie,
     About the "XmlHttpRequest is undefined" error in IE6, it may be caused by the way http request is created.
     Summary:
1.       ajaxmappane.templ and mainframe.templ they use:
var request = new XMLHttpRequest();
2.       printablepage.templ and selectwithinui.templ they use:
    if(msie)
        reqHandler = new ActiveXObject("Microsoft.XMLHTTP");
    else
        reqHandler = new XMLHttpRequest();
     They are not inconsistent. Some may cause the problem.
     I test a build a week ago and can reproduce the error you mentioned. However after I update to latest code, the error disappear. Would you please try?
Thanks & regards,
Christine
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, August 06, 2009 7:57 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] RFC 71: Please review changes so far.
Hi All,
I would like some feedback on my RFC 71 implementation so far. Would also like to know if I'm doing anything wrong :-)
- Jackie
Some issues encountered:
- IE 6 doesn't give you the initial view of the map, it errors with "XmlHttpRequest is undefined". After you pan zoom, etc things operate as normal. I'll need to find out if this problem existed before my implementation work.
What is done:
- PHP viewer implementation
What is not done:
- Java viewer implementation
- .net viewer implementation
- Verifying functionality in Chrome, Safari
View this message in context: http://n2.nabble.com/RFC-71%3A-Please-review-changes-so-far.-tp3398407p3398407.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org<mailto:mapguide-internals at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
