[mapguide-internals] Selection-Issue with interim release
Jason Birch Jason.Birch at nanaimo.ca
Tue Aug 11 11:32:15 EDT 2009
Hi Andreas,
Yes, the mailing list strips off unknown attachments.
For this kind of problem, I'd suggest filing a ticket against Fusion's Trac system.
http://trac.osgeo.org/fusion/wiki/FilingBugs
I've submitted this problem and potential solution on your behalf here:
http://trac.osgeo.org/fusion/ticket/276
Jason
-----Original Message-----
Sent: Tuesday, August 11, 2009 6:57 AM
Subject: [mapguide-internals] Selection-Issue with interim release
A few days ago I wrote about a selection problem in the interim build (selection not displayed on the map) - after investigating a bit the attached patch resolved the problem for me:
-The original call had the wrong number/types of parameters -the tiled version of the query layer didn't work for me, so I changed it to singletile -if the query layer has isBaseLayer=true, the layer is not redrawn/adjusted when zooming around
More information about the mapguide-internals mailing list
