[mapguide-internals] interim build
Andreas Morf a.morf at fkl.ch
Wed Aug 12 04:37:53 EDT 2009
Yes, in a way:
For some reason, the toolbar menus do not have the function setTooltip()
anymore - I've set them in my application definition with Mapguide Studio
2009
And furthermore the is an issue with reading all MapGroups into the MapMenu
For both of these issue I'll submit a ticket with workaround patch...
Andreas
> Did you find a solution to the toolbar problem you were seeing?  Is it
> visible in one of the bundled MapGuide themes?
> Jason
> -----Original Message-----
> From: Andreas Morf
> Sent: Wednesday, August 05, 2009 6:23 AM
> To: 'MapGuide Internals Mail List'
> Subject: RE: [mapguide-internals] interim build
> I tested interim build 4114 - looks quite good but there are a few
> defects in fusion viewer which I cannot resolve myself:
> - selection only displays selected objects in the selection panel but
> are not highlighted on the map
> - the toolbar(Main Menu) is not displayed at all
> - the overview map looks quirky (see attachment)
> Any ideas
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
