[mapguide-internals] RE: Review FixOperationVersion.patch
Tom Fukushima tom.fukushima at autodesk.com
Thu Aug 13 13:05:10 EDT 2009
I told Christine that we use 1.0.0 for new APIs.  Sorry Christine if I was wrong!
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Wednesday, August 12, 2009 10:28 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: Review FixOperationVersion.patch
Hi Christine,
Please check with Bruce on the operation version convention.
As far as I know, we were using the MapGuide version for any newly introduced operation versions.  This means a 1.0.0 operation version is supported in MapGuide version 1.0.0 or later.  A 2.2.0 operation is supported in MapGuide 2.2.0 or later.
If a new version of an operation is introduced in MapGuide 2.2.0, then the new operation version should be set to 2.2.0.
If I am correct about the convention, this patch is not required.
Thanks,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Christine Bao
Sent: August 12, 2009 1:31 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Review FixOperationVersion.patch
Hi all,
     A patch http://trac.osgeo.org/mapguide/attachment/ticket/1026/FixOperationVersion.patch is attached for ticket http://trac.osgeo.org/mapguide/ticket/1026. Would you please review it? Thank you.
     The comment for this submission:
     The operation version should be 1.0.0 for new added API, and it has nothing to do with MapGuide version. This patch fixed the API GetSessionTimeout()'s version from 2.2.0 to 1.0.0.
Thanks & regards,
Christine
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
