[mapguide-internals] Apache Service event 3299
Jason Birch Jason.Birch at nanaimo.ca
Tue Aug 18 11:17:51 EDT 2009
OK, that's odd.  I have to admit I haven't tried that combination myself as I don't install MapGuide on my development machine (I don't develop against MapGuide core) and don't use Apache.
If we knew why it was causing this problem to have VS installed, maybe we could work around it, but I don't have any idea how to find out.
I wonder if it's an sxs/version problem with the runtimes.  Any chance you could try (re-)installing the MSVC++ runtimes and SP runtimes for VS2005 and VS2008 and see if it helps? Pretty long shot...
http://www.microsoft.com/downloads/details.aspx?familyid=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en
http://www.microsoft.com/DOWNLOADS/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Jason
-----Original Message-----
Sent: Tuesday, August 18, 2009 7:21 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] Apache Service event 3299
Hi Jason,
The problem arises when VS2005 or VS2008 is already installed on the
computer.
Pierre
Jason Birch wrote:
> Haven't seen this before, so not sure what the solution is.
> You could try re-installing the MS VC++ Runtime libraries, but those are
> normally not detected by depends.
> Is J: a locally attached hard drive?  Is it possible to try installing
> under C:\Apps or something like that to rule out networking and
> locale-related problems?
> Jason
> From: pcardinal
> Sent: Monday, August 17, 2009 1:26 PM
> Subject: Re: [mapguide-internals] Apache Service event 3299
> I am on 32-bit. And effectively, depends.exe complains on
> MgHttpHandler.dll
> Error: At least one required implicit or forwarded dependency was not
> found.
> Warning: At least one delay-load dependency module was not found.
> Warning: At least one module has an unresolved import due to a missing
> export function in a delay-load dependent module.
> MSVCR90.DLL Error opening file. Le fichier spécifié est intouvable(2).
> [translation: the file is not found]
> IESHIMS.DLL Error opening file. Le fichier spécifié est intouvable(2).
> What is the solution?
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Apache-Service-event-3299-tp3452312p3466327.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
