[mapguide-internals] RFC 81 is ready for review
Jason Birch
Jason.Birch at nanaimo.ca
Mon Aug 24 12:40:59 EDT 2009
I see the value of this tool, but I would not be happy to see it replace a basic selection widget. It's too GIS/CAD, with far too many choices for a non-expert to figure out.
More to say, but have to go...
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Mon Aug 24 08:56:44 2009
Subject: RE: [mapguide-internals] RFC 81 is ready for review
There's no point in having redundant functionality. This RFC seems to cover
RFC 71 and more. I have no qualms about suspending/cancelling my work on RFC
71.
- Jackie
Buddy Hu wrote:
> Hi Kenneth, Thanks for your reply!
> About the overlap with RFC 71, I think we don't make any changes to the
> existing Selection Panel. If Jackie want to introduce the Selection Panel
> to the AJAX view, I am pleasure to see this happens. If not, I think the
> Feature Inspector panel will cover some functionalities of the Selection
> Panel.
> For the typo of "Inverse Selection", I will update it later. Thanks for
> your good catch.
> And I don't think we need any server or Webserver code changes for this
> RFC. I will clarify these in the "Implications" part.
> And I'm not intent to support the sort or filter for the properties now.
> For the Gzip, we get this suggestion from Paul Spencer. I didn't do any
> test for this yet. For more details, you can check the mail I attached.
> Thanks for your reply again! I will update my RFC and post it again.
> -Buddy
> -----Original Message-----
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Skovhede, GEOGRAF A/S
> Sent: Friday, August 21, 2009 4:04 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC 81 is ready for review
> This overlaps a bit with RFC 71:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc71
> At least the tree for display in the AJAX viewer should be present
> there, and I belive Jackie has developed this already?
> There is a slight spelling error in the "Inverse selection" menu item.
> Are there any changes required in the server code, or is this done with
> the current selection system?
> There has been questions about the order of properties, some want them
> sorted, some want them as is, will there be an option to select sort
> modus?
> To use GZip compression, is it possible to just serve the .gz file or
> does it require a webserver change to supply the compression header?
> I seem to recal that some browsers do not support GZip compression, and
> the served file should obey the compression flag to ensure compatibility.
> If a webserver change is required, will the change include maintenance
> for the installer?
> The test plan should include testing with a range of browsers.
> I am overall positive, the preview looks cool, and the addition is
> sorely needed.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Buddy Hu skrev:
>> Hi All,
>> The RFC 81- Add a new widget Feature Inspector is ok for review.
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc81
>> Any comments will be appreciated.
>> Thanks,
>> -Buddy Hu
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/RFC-81-is-ready-for-review-tp3485127p3504295.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
