[mapguide-internals] MapGuide Enterprise 2010 SP1 Selected Features Feature Reader
Carl Jokl carl.jokl at keynetix.com
Wed Aug 26 10:29:50 EDT 2009
Firstly I know that this forum is aimed at users of MapGuide Open Source
rather than MapGuide Enterprise but recently the company I work for has
patched its MapGuide 2010 and Web Server Extensions with the new Service
Pack 1. Since doing so some errors are occurring with feature readers based
on map selection. I know that MapGuide Enterprise is generally based on
stable snapshots of the MapGuide open source project. I wonder if MapGuide
Enterprise 2010 sp1 is matched with a corresponding MapGuide OpenSource
version and if so which version matches or most closely matches it.
The problem is encountered when trying to get the type id of a property in
the feature reader. This is causing an MgObjectNotFound exception but I am
not sure as to the cause. I have tried changing the property which is
checked in this way but encounter the same problem.
I know that SP1 did a lot of work with map selection and as this operation
is related to getting a feature reader for selection I wanted to see if any
changes in SP1 have caused this problem. Has anyone else had any similar
problems.
Regards Carl
View this message in context: http://n2.nabble.com/MapGuide-Enterprise-2010-SP1-Selected-Features-Feature-Reader-tp3515099p3515099.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
