[mapguide-internals] RFC 49 parameter logging delimiters tweak
Bruce Dechant bruce.dechant at autodesk.com
Mon Feb 2 14:59:02 EST 2009
Zac,
I just submitted a fix for this as the logging enhancements for RFC49 should be using the serverconfig.ini setting LogsDelimiter for the delimiter character and not a hard coded comma character.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Friday, December 26, 2008 10:54 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RFC 49 parameter logging delimiters tweak
Currently the delimiters for the parameters use a comma as the
delimiter between the options,
it makes parsing the parameters harder than neccesary as there are
often commas in the WKT
Resource=Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource,ClassName=SDF_2_Schema:VotingDistricts,Options={{Operator=1}{GeomProp=Data}{GeomOp=10}{Geometry=POLYGON
((-87.783866628374042 43.691398128787803, -87.676641873488435
43.691398128787803, -87.676641873488435 43.797520000480297,
-87.783866628374042 43.797520000480297, -87.783866628374042
43.691398128787803))}}
Would it make sense to use a semi-colon instead, just to make parsing
this easier?
I am writing a up little php script which parses the Trace.log and
re-executes the
query for performance profiling
Enhancing the END entries by adding the BGN parameters and elapsed time, maybe
as level 4 would make the log files useful without pre-processing
z
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
