[mapguide-internals] About the WiX installer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 17 02:55:24 EST 2009
I had to re-run some of the Parafin scripts to match the actual files on
my machine.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Hey Jackie,
> There are some path variables in the project properties that you will have to point to the correct locations...  I think that should be it.
> Note; I may have used a static fdo pointing to a pre beta 3.4 release, and geos was made dynamic so that dll will need to be added to the files.
> Jason
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
> Sent: Mon Feb 16 20:38:23 2009
> Subject: [mapguide-internals] About the WiX installer
> Hi All,
> I'm trying to grok the WiX installer files. When trying to build the wix
> installers, it is erroring out because it can't find a whole load of files.
> Given a checkout of the mapguide svn trunk, what do I need to do to ensure
> the wix installers build without problems?
> - Jackie
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
