[mapguide-internals] PATCH: Fix for ticket #593
alucas alucas at svl.es
Tue Feb 17 14:45:18 EST 2009
Thanks for the Info Tom.
Tom Fukushima wrote:
> Thanks. That problem has already been fixed.  I have updated the ticket
> with the details.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of alucas
> Sent: Tuesday, February 17, 2009 3:02 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] PATCH: Fix for ticket #593
> Hello,
> I think to have the solution for this bug. The problem was in the mapDevH
> calculation, when the viewer is initialized the function ResizeMapSpace is
> called and the mapDevH calculation is wrong. After this, in the function
> delayInit the calculation is corrected, but the mapSpace has been created
> before and the height is wrong. My solution is to force a ResizeMapSpace()
> when the mapDevH is correct in this method. In this way, it seems to work
> fine.
> This is the code modified in ajaxmappan.templ:
> function delayInit()
>  mapDevW = mapCell.offsetWidth;
>  mapDevH = (safari ? document.body.offsetHeight: mapCell.offsetHeight);
> //height of inner elements not set on safari
> // FIX
> ResizeMapSpace();
> RestoreState();
> Regards.
> http://n2.nabble.com/PATCH%3A-Fix-for-ticket--593-tp2339979p2339979.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/PATCH%3A-Fix-for-ticket--593-tp2339979p2342858.html
More information about the mapguide-internals mailing list
