[mapguide-internals] About the WiX installer
Jackie Ng jumpinjackie at gmail.com
Thu Feb 19 09:10:28 EST 2009
I've hacked the wix installer files so that it writes the correct paths to
serverconfig.ini
Patch is here: http://trac.osgeo.org/mapguide/ticket/855
I might have done it a bit cumbersomely (wix noob here)
- Jackie
Jason Birch wrote:
> Looks like there is a version of Paraffin that works with 3.0 now:
> http://tinyurl.com/cd43qz <http://tinyurl.com/cd43qz>
> So re-generating the files listings and setting up file includes that can
> be kept up to date with Paraffin is probably a great idea anyway.  Note: I
> believe that some files (providers.xml, serverconfig.ini, etc) will need
> to be removed from the autogenerated file listings and managed separately
> so they can be referenced consistently in custom actions.
> I had actually explored using heat to generate some of these file lists
> because of my frustration editing Paraffin files, but Parrafin 3 tilts the
> field back in its favour.  heat is still useful for harvesting IIS website
> settings.
> Jason
> ________________________________
> From: Kenneth Skovhede, GEOGRAF A/S
> Sent: Mon 2009-02-16 11:55 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] About the WiX installer
> I had to re-run some of the Parafin scripts to match the actual files on
> my machine.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/About-the-WiX-installer-tp2339047p2353186.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
