[mapguide-internals] Bounderies between mapguide Server andClients
    Jason Birch
    Jason.Birch at nanaimo.ca
    Fri Feb 20 12:43:25 EST 2009
Apart from initial development costs and maintenance issues, the main
problem that I see would be keeping the APIs in sync.  There is
considerable benefit in being able to do the same thing using the same
(or similar) methods across all of the APIs.  The risk of dedicated APIs
getting out of sync as far as capabilities go is considerable,
especially for APIs like Java which don't seem to be getting much open
source love.
Despite this I agree that, given unlimited resources, dedicated APIs for
each language would be desirable.  In fact, Kenneth's "Maestro API"
isn't an API to Maestro, it's a native C# API to MapGuide, so there's at
least one example of a community effort to develop a language-specific
API.
Jason
-----Original Message-----
Sent: February-20-09 9:16 AM
Subject: Re: [mapguide-internals] Bounderies between mapguide Server
andClients
I am curious on a couple of points raised though by the answer. The fact
that it seems Autodesk would not wish to change from the approach they
currently employ using wrappers is not so much of a surprise as I
espected
that would probably be the case. Given the open source nature of
mapguide
though it does not rule out the possibility of someone outside Autodesk
trying it out.
More information about the mapguide-internals
