[mapguide-internals] VOTE: Add Jackie Ng as a committer (Re: OSGeo Project Contributor agreements)
Jackie Ng jumpinjackie at gmail.com
Tue Feb 24 19:08:33 EST 2009
I submitted two contributor agreements months ago (one for FDO and one for
MGOS). I never knew if the MGOS one got accepted.
2008/10/15 Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
> Good to know!  Works for me, thank you.
> Bob - can we get MGOS onto the CLA somewhere?
> Begin forwarded message:
>  From: "Jackie Ng" <jumpinjackie at gmail.com>
>> Date: October 14, 2008 12:46:47 PM PDT (CA)
>> To: "Tyler Mitchell (OSGeo)" <tmitchell at osgeo.org>
>> Subject: Re: OSGeo Project Contributor agreements
>> Hi Tyler,
>> The MGOS one does not mention the actual project name. Hence I wrote it on
>> the back of the document.
>> See for yourself: http://mapguide.osgeo.org/files/Individual%
>> 20Contributor%20Agreement.pdf
>> - Jackie
>> Hi Jackie,
>> Sorry for a slow response, I've been on vacation.  I received your
>> documents, thank you.  Did you keep a copy of them?  The reason I ask is
>> that the FDO one is fine, but the other one did not mention what project it
>> was for.  I will need you to resend that one.  I notice you say it is for
>> MGOS - was that mentioned anywhere in the document?  I might just have a bad
>> eyes.
>> I keep track of all contributor agreements here:
>> http://wiki.osgeo.org/wiki/Contributor_Agreements_Received
>> Hope that helps.  I was going to follow up with anyway, so thank you for
>> being in touch.  I'm your primary contact on this topic.
>> Tyler
>> On 6-Oct-08, at 2:23 AM, Jackie Ng wrote:
>> Hi All,
>> I recently (a week and a bit ago) mailed two signed Project Contributor
>> agreement documents (one for MapGuide Open Source and one for Feature Data
>> Objects), my questions are:
>> 1) What is the usual turnaround time for Project Contributor agreements be
>> processed?
>> 2) How will I know if my mailed agreements have been accepted?
>> Regards,
>> - Jackie
Blog: http://themapguyde.blogspot.com
LinkedIn: http://www.linkedin.com/in/jackieng
Twitter: http://twitter.com/jumpinjackie
"A SQL query walks into a bar and sees two tables. He walks up to them and
says 'Can I join you?'"
More information about the mapguide-internals mailing list
