[mapguide-internals] Re: Please review RFC 66
Christine Bao Christine.Bao at autodesk.com
Mon Jun 22 02:05:41 EDT 2009
Hi Kenneth,
     Thank you for your suggestion. Here are my comments:
1.       A real function to support "keep alive" pings
We plan to call "GETFEATUREPROVIDERS" through MapAgent to keep alive. This function is light-weighted and won't cause much overhead. Using this method is the easiest way to approach it. Your suggestion makes sense, but we'll need to add another API which is only for this purpose, so we decide not to do this.
2.       The client read out timeout value to adjust ping interval
I'm afraid it's too much complicated. The plan is to ping server at a fixed time interval (of course you can set it in configuration), and the interval won't change during runtime. It works as Fusion does.
3.       Connection broken
Once the connection broken or timeout because server down, the client will stop ping server. But it will not recovery from a broken/timeout session.
Thanks & regards,
Christine
Message: 3
Date: Fri, 19 Jun 2009 12:41:14 +0200
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
Subject: Re: [mapguide-internals] RE: Please review RFC 66
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Message-ID: <4A3B6B4A.7050206 at geograf.dk>
Content-Type: text/plain; charset=ISO-8859-3; format=flowed
I commented on the issue as well.
You are free to ignore it, but in case you somehow missed it, here it is:
http://n2.nabble.com/Please-review-RFC-66-tc3090381.html#a3092233
Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals mailing list
