[mapguide-internals] Re: Please review RFC 66
Trevor Wekel trevor.wekel at autodesk.com
Mon Jun 22 05:04:35 EDT 2009
I think just that the operation completed successfully.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, June 22, 2009 3:02 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: Please review RFC 66
seem to work well
i did a test by creating one session, then creating another
and then closing the first and testing is the session:close_session_id exists
which returned no/false ( as Administrator)
out of interest, in the admin log even tho ResourceExists returned
False, it logs as sucess
<2009-06-22T18:55:38>
	1816			Administrator	ResourceExists.1.0.0:1(Session:61b8e4b0-4138-102c-8000-005056c00008_en_7F0000010AFC0AFB0AFA//)
Success
does Success in these logs indicate the result, or just that the
operation completed?
z
On Mon, Jun 22, 2009 at 6:26 PM, Zac Spitzer<zac.spitzer at gmail.com> wrote:
> ahh, of course, thanks Trevor, I'm actually wokring on upgrading an app to 2.1
> at the moment, I'll try it
> z
> On Mon, Jun 22, 2009 at 6:21 PM, Trevor Wekel<trevor.wekel at autodesk.com> wrote:
>> Hi Zac,
>> I think ResourceExists is implemented in 2.1.  I wonder if MgResourceService.ResourceExists would work on the root of the session repository "Session:xxyyzz-abc//"?  Alternatively you could check for the existence of the MgMap object "Session:xxyyzz-abc//MyMapName.Map".
>> ResourceExists does return a boolean.
>> Thanks,
>> Trevor
>> ________________________________________
>> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>> Sent: Monday, June 22, 2009 2:10 AM
>> Frustratingly, there isn't currently a nice simple way to check if a
>> session is valid without getting into exception and error log territory
>> Adding something like MgSite.isValidSession(sessionId) which returns
>> a boolean result would be really useful and elimate the need for klunky
>> workarounds.
>> z
>> On Mon, Jun 22, 2009 at 4:55 PM, Kenneth Skovhede, GEOGRAF
>> A/S<ks at geograf.dk> wrote:
>>> 1)
>>> On my setup "GETFEATUREPROVIDERS" returns 13Kb worth of xml.
>>> It may not consume CPU resources, but it does consume bandwidth,
>>> especially since it is not required, and it happens a fixed intervals,
>>> even if the user is inactive.
>>> If its too much work to put in a real function, I think Zac's proposal is
>>> way better,
>>> but I'm not sure it will work if admin functions are disabled in the
>>> WebTier.
>>> 2)
>>> There is a clear 1-1 relation between the server timeout setting and the
>>> client ping setting.
>>> If you can read the timeout value on viewer startup, that is fine, but I
>>> don't think you can.
>>> If you require the admin-user to change the time in two places, you can be
>>> certain
>>> that there will be a pile of support requests.
>>> Also, for a non-specialist, it is not immediately obvious that the two
>>> should not be the
>>> same, eg. setting both to 15 minutes will make the sessions expire at
>>> random, due to races
>>> and clock drift.
>>> 3) I have seen scenarios where a single reqest fails.
>>> If you know the duration of the session, it is easy to ignore "connection
>>> broken" responses,
>>> and only stop pinging when there has been no positive response within a
>>> session duration.
>>> I think you need to adress issue 1 and 2.
>>> Issue 3 is easy and will improve failure resilience, but not required.
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> Zac Spitzer skrev:
>>>> how about GETSITEVERSION ? that's what I have used for keepalives in
>>>> my own stuff
>>>> and it returns a much smaller response?
>>>> z
>>>> On Mon, Jun 22, 2009 at 4:05 PM, Christine
>>>> Bao<Christine.Bao at autodesk.com> wrote:
>>>>> Hi Kenneth,
>>>>>    Thank you for your suggestion. Here are my comments:
>>>>> 1.       A real function to support "keep alive" pings
>>>>> We plan to call "GETFEATUREPROVIDERS" through MapAgent to keep alive.
>>>>> This function is light-weighted and won't cause much overhead. Using this
>>>>> method is the easiest way to approach it. Your suggestion makes sense, but
>>>>> we'll need to add another API which is only for this purpose, so we decide
>>>>> not to do this.
>>>>> 2.       The client read out timeout value to adjust ping interval
>>>>> I'm afraid it's too much complicated. The plan is to ping server at a
>>>>> fixed time interval (of course you can set it in configuration), and the
>>>>> interval won't change during runtime. It works as Fusion does.
>>>>> 3.       Connection broken
>>>>> Once the connection broken or timeout because server down, the client
>>>>> will stop ping server. But it will not recovery from a broken/timeout
>>>>> session.
>>>>> Thanks & regards,
>>>>> Christine
>>>>> Message: 3
>>>>> Date: Fri, 19 Jun 2009 12:41:14 +0200
>>>>> From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
>>>>> Subject: Re: [mapguide-internals] RE: Please review RFC 66
>>>>> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
>>>>> Message-ID: <4A3B6B4A.7050206 at geograf.dk>
>>>>> Content-Type: text/plain; charset=ISO-8859-3; format=flowed
>>>>> I commented on the issue as well.
>>>>> You are free to ignore it, but in case you somehow missed it, here it is:
>>>>> http://n2.nabble.com/Please-review-RFC-66-tc3090381.html#a3092233
>>>>> _______________________________________________
>>>>> mapguide-internals mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals_______________________________________________
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
