[mapguide-internals] Installer Automated build
Jackie Ng jumpinjackie at gmail.com
Fri Mar 6 04:11:32 EST 2009
The installer build.bat should've been updated to not search for this
directory.
- Jackie
Kenneth Skovhede, GEOGRAF A/S wrote:
> Awesome.
> I have produced this small build script, based on the instructions on
> your blog:
> cd MgDev
> cmd /C build.bat -a=build -w=all
> cmd /C build.bat -a=install -w=all
> cd ..\Tools\Maestro
> cmd /C build.bat -a=buildinstall
> cd ..\..\Installer
> cmd /C build.bat -a=prepare
> cd ..
> And I can now build the MSI from scratch!
> Ps:
> The -a=regen option seems to have a slight problem when looking for the
> folder "%INSTALLER_DEV%\Support\Web\mapviewer", as it is not in SVN,
> and not prepared in the steps.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jackie Ng skrev:
>> Hi Kenneth,
>> MgDev\build.bat with no parameters does the build. You then need to run
>> it
>> with the -a=install parameter which will copy all the files to a staging
>> area in MgDev\<Debug|Release>, which you can override with -o=<my staging
>> directory>
>> But if you override the staging directory, you will have to specify this
>> directory when running the build.bat for the installer.
>> I've detailed the build instructions here:
>> http://themapguyde.blogspot.com/2009/03/building-mapguide-on-windows-made.html
>> - Jackie
>>> I just tried a fresh checkout today.
>>> After building MapGuide, using the "build.bat", I get the folder
>>> MgDev\Server\bin\Release
>>> But the "build.bat -a=regen" in the Installer looks for
>>> ..\MgDev\Release\Server\Bin
>>> And that second folder is supposed to contain other stuff (like the repo
>>> admin files).
>>> Do I have to perform another step to get that special folder prepared?
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-Automated-build-tp2432681p2434646.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
