[mapguide-internals] Installer: Yeah baby!
Jason Birch
Jason.Birch at nanaimo.ca
Wed Mar 11 20:42:02 EDT 2009
Awesome.
Just ran through the installation on Win2k3.
- Installed .Net 2.0 and VC redistributables
- Ran installer, chose IIS, PHP, left the feature tree at defaults,
rebooted
- Connected to MapAdmin: no problem
- Connected to MapAgent: no problem
- Loaded up /mapguide/fusion/templates/mapguide/standard/index.html : no
problem
There are definitely still some issues and need to test different
configs, but... this is cool!
Here's what I did to build:
- Copied FDO 3.4 RC2 into correct locations and installed prereqs as per
Jackie's blog
- Modified Mapguide and Installer build.bat to point to local tool
locations
- Started my VS2008 command prompt and went to my main SVN directory
pushd MGDev
call build.bat -a=build -w=all
call build.bat -a=install -w=all -o=C:\Staging\
popd
pushd maestro
pushd Maestro
call "Update RELEASE Environment.bat"
popd
call build.bat -a=install -o=C:\Staging\Maestro
popd
pushd installer
call build.bat -a=prepare -web=C:\Staging\WebServerExtensions
-srv=C:\Staging\Server -maestro=C:\Staging\Maestro
call build.bat -a=regen -web=C:\Staging\WebServerExtensions
call build.bat -a=build -web=C:\Staging\WebServerExtensions
popd
Jason
More information about the mapguide-internals
