[mapguide-internals] Installer: Yeah baby!
Jackie Ng jumpinjackie at gmail.com
Thu Mar 12 02:09:51 EDT 2009
Does the webconfig.ini file check out? It gets written during installation.
The IIS7 custom action project is in the solution, but hasn't been used or
referenced anywhere yet.
I also haven't incorporated any II6-specific logic in the custom actions
(wrt tickets #360 and #361)
- Jackie
Jason Birch wrote:
> I'm having some problems with my 2003 install, but I think that perhaps
> one of the authoring tools I tried against it messed up the repository.
> It was initially loading the map, but now it just fails and doing
> something like enumerateresources gives me a configuration error
> regarding webconfig.ini; guessing it can't open a connection to the
> server.  Will try rebuilding my repositories tomorrow and re-importing
> the demo and see what happens.
> The 2008 installer picks up IIS7 fine.  It needs to somehow check for
> appropriate permissions because when it runs under UAC when not launched
> with elevated permissions, it fails silently and rolls back.  The actual
> IIS7 custom action doesn't seem to work; none of the IIS7 web site
> settings seem to take.
> Also, I noticed a local build error in MapGuide; it couldn't find a
> reference for the ASP.Net web extension project (so I'm guessing that
> they failed to build) and they don't show up in the installer either.
> Maybe this is what's causing problems with the IIS7 config?
> Jason
> -----Original Message-----
> From: Jason Birch
> Sent: March-11-09 5:42 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Installer: Yeah baby!
> Awesome.
> Just ran through the installation on Win2k3.
> - Installed .Net 2.0 and VC redistributables
> - Ran installer, chose IIS, PHP, left the feature tree at defaults,
> rebooted
> - Connected to MapAdmin: no problem
> - Connected to MapAgent: no problem
> - Loaded up /mapguide/fusion/templates/mapguide/standard/index.html : no
> problem
> There are definitely still some issues and need to test different
> configs, but... this is cool!
> Here's what I did to build:
> - Copied FDO 3.4 RC2 into correct locations and installed prereqs as per
> Jackie's blog
> - Modified Mapguide and Installer build.bat to point to local tool
> locations
> - Started my VS2008 command prompt and went to my main SVN directory
> pushd MGDev
> call build.bat -a=build -w=all
> call build.bat -a=install -w=all -o=C:\Staging\
> popd
> pushd maestro
> pushd Maestro
> call "Update RELEASE Environment.bat"
> popd
> call build.bat -a=install -o=C:\Staging\Maestro
> popd
> pushd installer
> call build.bat -a=prepare -web=C:\Staging\WebServerExtensions
> -srv=C:\Staging\Server -maestro=C:\Staging\Maestro
> call build.bat -a=regen -web=C:\Staging\WebServerExtensions
> call build.bat -a=build -web=C:\Staging\WebServerExtensions
> popd
> Jason
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2465800.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
