[mapguide-internals] error with testing 2.1
Jason Birch Jason.Birch at nanaimo.ca
Mon Mar 16 04:05:33 EDT 2009
Don't suppose you have a small data set or package to test with?
If you initially created your data/layer/map with something that didn't use CS-Map, it's possible that it can't be read correctly.  Seems a bit odd though...
Are all of your layers and the map in the same CS?
Jason
Sent: Sun 2009-03-15 2:43 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] error with testing 2.1
On xp sp3 using a test installer from jason, i am getting this error
with a map in epsg:4283
The coordinate system initialization failed.
Could not initialize the geodetic transformation.
the path is correct
MENTOR_DICTIONARY_PATH=C:\Program Files\OSGeo\MapGuide
Server\CSMap\Dictionaries\
sheboygan sample however does works fine
any ideas?
More information about the mapguide-internals mailing list
