[mapguide-internals] Installer: Yeah baby!
Jackie Ng jumpinjackie at gmail.com
Mon Mar 16 08:49:07 EDT 2009
I've integrated the IIS7 actions into the installer. IIS5/6 actions and IIS7
actions should be mutually exclusive.
I would like to know if there are any problems on Vista. I just tried
running the installer on my Windows 7 beta VM (on the assumption it is Vista
minus the narky UAC) without success because it couldn't copy the CRT dlls
into the winsxs directory. I wonder if it is the same for Vista.
- Jackie
Jason Birch wrote:
> It looks ok as far as I can tell, and was working ok initially...  I got
> maps, but now I can't.  I can haz maps?
> I'll stick to 2003 until IIS7 gets incorporated then... I wouldn't worry
> about those tickets until other stuff works :)
> J
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org
> <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org
> <mapguide-internals at lists.osgeo.org>
> Sent: Wed Mar 11 23:09:51 2009
> Subject: RE: [mapguide-internals] Installer:  Yeah baby!
> Does the webconfig.ini file check out? It gets written during
> installation.
> The IIS7 custom action project is in the solution, but hasn't been used or
> referenced anywhere yet.
> I also haven't incorporated any II6-specific logic in the custom actions
> (wrt tickets #360 and #361)
> - Jackie
> Jason Birch wrote:
>> I'm having some problems with my 2003 install, but I think that perhaps
>> one of the authoring tools I tried against it messed up the repository.
>> It was initially loading the map, but now it just fails and doing
>> something like enumerateresources gives me a configuration error
>> regarding webconfig.ini; guessing it can't open a connection to the
>> server.  Will try rebuilding my repositories tomorrow and re-importing
>> the demo and see what happens.
>> The 2008 installer picks up IIS7 fine.  It needs to somehow check for
>> appropriate permissions because when it runs under UAC when not launched
>> with elevated permissions, it fails silently and rolls back.  The actual
>> IIS7 custom action doesn't seem to work; none of the IIS7 web site
>> settings seem to take.
>> Also, I noticed a local build error in MapGuide; it couldn't find a
>> reference for the ASP.Net web extension project (so I'm guessing that
>> they failed to build) and they don't show up in the installer either.
>> Maybe this is what's causing problems with the IIS7 config?
>> Jason
>> -----Original Message-----
>> From: Jason Birch
>> Sent: March-11-09 5:42 PM
>> Subject: [mapguide-internals] Installer: Yeah baby!
>> Awesome.
>> Just ran through the installation on Win2k3.
>> - Installed .Net 2.0 and VC redistributables
>> - Ran installer, chose IIS, PHP, left the feature tree at defaults,
>> rebooted
>> - Connected to MapAdmin: no problem
>> - Connected to MapAgent: no problem
>> - Loaded up /mapguide/fusion/templates/mapguide/standard/index.html : no
>> problem
>> There are definitely still some issues and need to test different
>> configs, but... this is cool!
>> Here's what I did to build:
>> - Copied FDO 3.4 RC2 into correct locations and installed prereqs as per
>> Jackie's blog
>> - Modified Mapguide and Installer build.bat to point to local tool
>> locations
>> - Started my VS2008 command prompt and went to my main SVN directory
>> pushd MGDev
>> call build.bat -a=build -w=all
>> call build.bat -a=install -w=all -o=C:\Staging\
>> popd
>> pushd maestro
>> pushd Maestro
>> call "Update RELEASE Environment.bat"
>> popd
>> call build.bat -a=install -o=C:\Staging\Maestro
>> popd
>> pushd installer
>> call build.bat -a=prepare -web=C:\Staging\WebServerExtensions
>> -srv=C:\Staging\Server -maestro=C:\Staging\Maestro
>> call build.bat -a=regen -web=C:\Staging\WebServerExtensions
>> call build.bat -a=build -web=C:\Staging\WebServerExtensions
>> popd
>> Jason
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2465800.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2485737.html
More information about the mapguide-internals mailing list
