[mapguide-internals] Installer: Yeah baby!
Martin Morrison martin.morrison at edsi.com
Mon Mar 16 09:10:23 EDT 2009
Time is always the issue.  In order to build it I would have to hurry up and get all of the tools loaded on the new laptop, (64 bit) and dig out the old laptop (32-bit), so we would be looking at quite a bit of effort before I even start to test the install.  In my opinion this is why we should have pre-compiled builds ready for testing.  This would increase the amount of testing that could be completed by people who don't have a huge amount of time to devote to the project.
Note that I am NOT proposing a new build with every little change, just ones that have major fixes, or weekly/bi-weekly etc.  Am I correct that the release is scheduled within the next few weeks/month?
Martin
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, March 16, 2009 9:02 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] Installer: Yeah baby!
Hi Martin,
If you can't build one from trunk, maybe Jason could supply you a copy of
the installer.
- Jackie
Martin Morrison wrote:
> I can test Vista 64 and 32.  Do you have a beta copy somewhere for
> download?
> Martin
> Sent: Monday, March 16, 2009 8:49 AM
> Subject: Re: [mapguide-internals] Installer: Yeah baby!
> I've integrated the IIS7 actions into the installer. IIS5/6 actions and
> IIS7
> actions should be mutually exclusive.
> I would like to know if there are any problems on Vista. I just tried
> running the installer on my Windows 7 beta VM (on the assumption it is
> Vista
> minus the narky UAC) without success because it couldn't copy the CRT dlls
> into the winsxs directory. I wonder if it is the same for Vista.
> - Jackie
> Jason Birch wrote:
>> It looks ok as far as I can tell, and was working ok initially...  I got
>> maps, but now I can't.  I can haz maps?
>> I'll stick to 2003 until IIS7 gets incorporated then... I wouldn't worry
>> about those tickets until other stuff works :)
>> J
>> ----- Original Message -----
>> <mapguide-internals-bounces at lists.osgeo.org>
>> <mapguide-internals at lists.osgeo.org>
>> Sent: Wed Mar 11 23:09:51 2009
>> Does the webconfig.ini file check out? It gets written during
>> installation.
>> The IIS7 custom action project is in the solution, but hasn't been used
>> or
>> referenced anywhere yet.
>> I also haven't incorporated any II6-specific logic in the custom actions
>> (wrt tickets #360 and #361)
>> - Jackie
>> Jason Birch wrote:
>>> I'm having some problems with my 2003 install, but I think that perhaps
>>> one of the authoring tools I tried against it messed up the repository.
>>> It was initially loading the map, but now it just fails and doing
>>> something like enumerateresources gives me a configuration error
>>> regarding webconfig.ini; guessing it can't open a connection to the
>>> server.  Will try rebuilding my repositories tomorrow and re-importing
>>> the demo and see what happens.
>>> The 2008 installer picks up IIS7 fine.  It needs to somehow check for
>>> appropriate permissions because when it runs under UAC when not launched
>>> with elevated permissions, it fails silently and rolls back.  The actual
>>> IIS7 custom action doesn't seem to work; none of the IIS7 web site
>>> settings seem to take.
>>> Also, I noticed a local build error in MapGuide; it couldn't find a
>>> reference for the ASP.Net web extension project (so I'm guessing that
>>> they failed to build) and they don't show up in the installer either.
>>> Maybe this is what's causing problems with the IIS7 config?
>>> Jason
>>> From: Jason Birch
>>> Sent: March-11-09 5:42 PM
>>> Subject: [mapguide-internals] Installer: Yeah baby!
>>> Awesome.
>>> Just ran through the installation on Win2k3.
>>> - Installed .Net 2.0 and VC redistributables
>>> - Ran installer, chose IIS, PHP, left the feature tree at defaults,
>>> rebooted
>>> - Connected to MapAdmin: no problem
>>> - Connected to MapAgent: no problem
>>> - Loaded up /mapguide/fusion/templates/mapguide/standard/index.html : no
>>> problem
>>> There are definitely still some issues and need to test different
>>> configs, but... this is cool!
>>> Here's what I did to build:
>>> - Copied FDO 3.4 RC2 into correct locations and installed prereqs as per
>>> Jackie's blog
>>> - Modified Mapguide and Installer build.bat to point to local tool
>>> locations
>>> - Started my VS2008 command prompt and went to my main SVN directory
>>> pushd MGDev
>>> call build.bat -a=build -w=all
>>> call build.bat -a=install -w=all -o=C:\Staging\
>>> popd
>>> pushd maestro
>>> pushd Maestro
>>> call "Update RELEASE Environment.bat"
>>> popd
>>> call build.bat -a=install -o=C:\Staging\Maestro
>>> popd
>>> pushd installer
>>> call build.bat -a=prepare -web=C:\Staging\WebServerExtensions
>>> -srv=C:\Staging\Server -maestro=C:\Staging\Maestro
>>> call build.bat -a=regen -web=C:\Staging\WebServerExtensions
>>> call build.bat -a=build -web=C:\Staging\WebServerExtensions
>>> popd
>>> Jason
>>> mapguide-internals mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> View this message in context:
>> http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2465800.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2485737.html
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2485820.html
More information about the mapguide-internals mailing list
