[mapguide-internals] error with testing 2.1
Hugues Wisniewski hugues.wisniewski at autodesk.com
Mon Mar 16 11:50:13 EDT 2009
CsMap handles this WKT correctly and maps it to the system LL-GDA94
And considering the syntax of this WKT it looks like CsMap was the module used to generate it in the first place
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, March 16, 2009 1:23 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] error with testing 2.1
this is the map projection
   <CoordinateSystem>GEOGCS["LL-GDA94",DATUM["GDA94",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]</CoordinateSystem>
   <Extents>
course i'll knock out a test package if i have to :)
z
2009/3/16 Jason Birch <Jason.Birch at nanaimo.ca>:
> Don't suppose you have a small data set or package to test with?
> If you initially created your data/layer/map with something that didn't use CS-Map, it's possible that it can't be read correctly.  Seems a bit odd though...
> Are all of your layers and the map in the same CS?
> Jason
> ________________________________
> From: Zac Spitzer
> Sent: Sun 2009-03-15 2:43 AM
> Subject: [mapguide-internals] error with testing 2.1
> On xp sp3 using a test installer from jason, i am getting this error
> with a map in epsg:4283
> The coordinate system initialization failed.
> Could not initialize the geodetic transformation.
> the path is correct
> MENTOR_DICTIONARY_PATH=C:\Program Files\OSGeo\MapGuide
> Server\CSMap\Dictionaries\
> sheboygan sample however does works fine
> any ideas?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
