[mapguide-internals] My MSI Install Issues
Jackie Ng jumpinjackie at gmail.com
Mon Mar 16 18:09:09 EDT 2009
How old is that installer? Because I can get both server-only and web-only
configurations without any errors.
- Jackie
Crispin_at_1Spatial wrote:
> Hi,
> Got another MSI today but can't get it to install... it rollsback at the
> end of the web services file-copy so I have two issues (logs are from the
> MSI install).
>  1) Server Only Install
> Looks like I am missing the service registration element?
> Info 1721. There is a problem with this Windows Installer package. A
> program required for this install to complete could not be run. Contact
> your support personnel or package vendor. Action: MgServerInstallCA,
> location: C:\Program Files\OSGeo\MapGuide Server\bin\mgserver.exe,
> command: install "MapGuide Server 2.1"
>  2) Web Server Extensions (.net Only)
> Gets so close... it's a bit harsh doing a complete rollback if the config
> fails - looks like there are things that try to run and fail even if I
> select to do a manual configuration.
> Action start 10:28:03: InstallFinalize.
> Action ended 10:28:19: InstallFinalize. Return value 3.
> Action ended 10:28:21: INSTALL. Return value 3.
> Action ended 10:28:21: ExecuteAction. Return value 3.
> Action start 10:28:21: FatalError.
> Action ended 10:28:32: FatalError. Return value 2.
> Action ended 10:28:32: INSTALL. Return value 3.
> === Logging stopped: 3/16/2009  10:28:32 ===
> MSI (c) (E4:B4) [10:28:32:168]: Product: MapGuide Open Source 2.1 --
> Configuration failed.
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2488773.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
