[mapguide-internals] Installer - work in progress
Jackie Ng jumpinjackie at gmail.com
Tue Mar 17 16:39:48 EDT 2009
Just an addendum:
If you run:
msiexec /i MapGuideOpenSource-2.1.0-Unofficial.msi /l*v log.txt
It will log the whole process making it easier to diagnose any problems.
- Jackie
Jason Birch wrote:
> Martin at EDSI has graciously placed a recent build of the installer in
> the following temporary location:
> http://gis.edsi.com/MapGuideOpenSource-2.1.0-Unofficial.msi
> This will only be available for a limited time, and should not be
> broadcast widely so their server doesn't get swamped, but it will give
> you a chance to try out the new installer if you have been following
> along but haven't had a chance to build your own yet.  The installer
> still needs considerable testing, especially to ensure that configurable
> items get set correctly, that all OS / API language combinations work,
> etc.
> There are some known issues with IIS7, and if you want to install under
> IIS7 you'll have to start up a command prompt "as Administrator" and run
> it like:
> Also, I thought I had resolved this (patch attached to ticket 911), but
> Crispin had to manually install the Visual C++ runtime (VS2008 SP1) for
> the installer to complete successfully.
> If you run into problems, please update or enter new trac tickets under
> the Installer component.
> Thanks,
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer---work-in-progress-tp2493651p2493696.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
