[mapguide-internals] My MSI Install Issues
Jason Birch Jason.Birch at nanaimo.ca
Wed Mar 18 04:47:46 EDT 2009
Looks like Jackie just committed these, so you should just be able to svn update the installer and rebuild.
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Wed Mar 18 01:42:03 2009
Subject: RE: [mapguide-internals] My MSI Install Issues
... I didn't!  Is this part of the SVN that needs an update?  Out the office
today but will get someone to try  a rebuild with the patches on W2k8.
Jason Birch wrote:
> After applying the patch, did you also remove the two lines from the
> MsvcRuntime.wxi file that attempt to load the MFC msm?  I think there
> was some kind of conflict there; after I modified it locally so that
> this include only loads the CRT msm, it ran through for me without
> having to pre-install the redistributable.
> Jason
> -----Original Message-----
> From: Crispin_at_1Spatial
> Sent: March-17-09 12:32 PM
> I found the same thing on Win2k8 / IIS7 but didn't have time again today
> to
> try a manual fix - just got no sessions created with the FCGI agent.
> I patched my copy of the installer using your 911 fix but still got
> rollback
> issues on a clean(ish) machine.  However, when I ran the EXE of the
> MFC/VS
> runtime first the install completed so there may still be issues with
> the
> config on that front.
> Look forward to the next installment...
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2495948.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
