[mapguide-internals] ServerRenderingService API bloated
UV uvwild at gmail.com
Wed Mar 18 23:38:47 EDT 2009
For clarification:
Is there a platform with a stupid compiler that does not understand C++
default arguments?
Or is there another particular reason why the ServerRenderingService
does not use default arguments  but instead provides 3 method signatures?
Its such a hazzle to read through all this code to find out eventually
that its simply default arguments which have not been implemented as
such.....
    virtual MgByteReader* RenderMap(MgMap* map,
                                    MgSelection* selection,
                                    CREFSTRING format);
                                    CREFSTRING format,
                                    bool bKeepSelection);
                                    CREFSTRING format,
                                    bool bKeepSelection,
                                    bool bClip);
instead of
                                    CREFSTRING format,
                                    bool bKeepSelection =true ,
                                    bool bClip=false);
and again here
                                    MgCoordinate* center,
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    MgColor* backgroundColor,
                                    CREFSTRING format);
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    bool bClip);
instead of
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    bool bKeepSelection = true,
                                    bool bClip= false);
More information about the mapguide-internals mailing list
