[mapguide-internals] ServerRenderingService API bloated
Trevor Wekel trevor.wekel at autodesk.com
Thu Mar 19 09:29:40 EDT 2009
Nope.  Our modified version of SWIG still does not support default arguments.
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Wednesday, March 18, 2009 10:12 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] ServerRenderingService API bloated
It's because SWIG did not support default arguments at that time (a few years ago). It may do now.
Steve.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Wednesday, March 18, 2009 9:39 PM
Subject: [mapguide-internals] ServerRenderingService API bloated
For clarification:
Is there a platform with a stupid compiler that does not understand C++
default arguments?
Or is there another particular reason why the ServerRenderingService
does not use default arguments  but instead provides 3 method signatures?
Its such a hazzle to read through all this code to find out eventually
that its simply default arguments which have not been implemented as
such.....
    virtual MgByteReader* RenderMap(MgMap* map,
                                    MgSelection* selection,
                                    CREFSTRING format);
                                    CREFSTRING format,
                                    bool bKeepSelection);
                                    CREFSTRING format,
                                    bool bKeepSelection,
                                    bool bClip);
instead of
                                    CREFSTRING format,
                                    bool bKeepSelection =true ,
                                    bool bClip=false);
and again here
                                    MgCoordinate* center,
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    MgColor* backgroundColor,
                                    CREFSTRING format);
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    bool bClip);
instead of
                                    double scale,
                                    INT32 width,
                                    INT32 height,
                                    CREFSTRING format,
                                    bool bKeepSelection = true,
                                    bool bClip= false);
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
