[mapguide-internals] Default installation location for data directories
Jason Birch Jason.Birch at nanaimo.ca
Tue Mar 24 18:32:57 EDT 2009
I believe LocalAppDataFolder varies based on the install type.  I think that if the Package's InstallPrivileges is not set to "limited" then it's not per-user.
The main problem with ProgramFiles is that it's not writable by default under UAC.  On w2k8 or Vista, if you download a file into Packages without elevating first, it won't be visible to the server.
At this point I don't really care about this all that much; in the future it may affect our support load.
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: March-24-09 3:12 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Default installation location for data directories
Is the LocalAppDataFolder not a "per-user" variable?
Since MapGuide runs as a service, I would prefer it to use the current
%PROGRAMFILES% system.
Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals mailing list
