[mapguide-internals] Build Server - CruiseControl?
Trevor Wekel trevor.wekel at autodesk.com
Thu Mar 26 11:07:52 EDT 2009
Hi UV,
Cruise control is an excellent option.  I was also looking into Buildbot.  I believe Buildbot may be better suited to performing simultaneous multi-platform builds since it has a master/slave model.  http://buildbot.net/trac
Thanks,
Trevor
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV [uvwild at gmail.com]
Sent: Thursday, March 26, 2009 7:56 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Build Server - CruiseControl?
Hello,
I had a lock at the build server and I am offering to set up cruise
control NET on this machine to run builds and show which build numbers
succeeded.
I have been using this previously in a distributed project team and I
believe CI is pretty much the state of the art.
(Why cruisecontrol? Its mature and sourceforged and I know it so I can
set it up!)
Cruisecontrol can be tuned in terms of the conditions when to run the build.
The results of those builds are available on a dashboard page on a web
server and as a tray icon on the users machine. (needs an open port)
Furthermore I can imagine an upload page which could be used to upload a
patch to the server thereby triggering
the checkout of the last revision, applying the patch and running a
build thereafter, reporting the results to the dashboard.
Any Comments?
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
