[mapguide-internals] RE: CS-Map in 2.1
Hugues Wisniewski hugues.wisniewski at autodesk.com
Thu Mar 26 12:11:16 EDT 2009
> whatever is absolutely required for MapGuide runtime
If you use only coordinate system that never use any grid file that will work, but there are many system that use grid files in this case you'll need all the .gdc files and the grid files themselves. That's a lot of data to download but what is absolutely required for someone will be very different for someone else
Most North American users will use systems that need the grid files inside:
http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev/Dictionaries/Usa/
so, those files will be is absolutely required for them
> I'd like to help to create a CS-Map SDK windows installer
Sure, an installer is more work but I wanted to post a compiled zip file on the Cs-Map site and got carried away with other things along the year. The zip file would likely be around 200MB. Maybe a bit more
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, March 25, 2009 10:43 PM
To: 'MapGuide Internals Mail List'
Subject: [mapguide-internals] RE: CS-Map in 2.1
Hugues,
To keep download time reasonable, I'd like to only include the compiled dictionaries (or whatever is absolutely required for MapGuide runtime).  I believe that all that's required are:
  *.csv
  *.mrt
  *.csd
Is this correct?
For users that want to mess around with their coordinate systems, I'd like to help to create a CS-Map SDK windows installer once the MapGuide one is out of the way, including all of the code, compiled dictionaries, update utilities, docs, etc.
Jason
Sent: March-25-09 5:25 PM
To: MapGuide Internals Mail List
The csv file is needed, that's the mapper for the EPSG and WKT engine, editable by the end user
The unneeded files in the installer, that come from http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev/Dictionaries/ are:
- the 5 asc files: coordsys.asc, datums.asc, ellipsoid.asc, mreg.asc, category.asc
- CS_COMP.c
- CS_DictDiff.c
- Compiler.mak
- Compiler.nmk
- Compiler.vcproj
Hugues
p.s: when the svn depot is created, 2.1 should point to http://svn.osgeo.org/metacrs/csmap/branches/12.01/
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
