[mapguide-internals] Installer testing
alucas alucas at svl.es
Fri Mar 27 19:36:32 EDT 2009
Hi Jason,
Problem solved, it seems that jdk 1.6 is not supported. I had installed jdk1.6.0_12 (update 12) and I installed the release 1.5.0_17 and then the service works well.
Regards.
Hi all,
I've uploaded a current-ish (last night) version of the open source installer with all of the grids (and preliminary version of the two raster patches applied) here:
http://download.osgeo.org/mapguide/testing/
This hasn't been thoroughly tested yet, so only apply it on test PCs.
There are still some defects.  The two main ones (I think) are:
- #930 : Fusion is expecting the web extensions to be installed under "webserverextensions".  We're not using that directory by default, and are allowing users to modify it during installation.
- #912 : The IIS7 custom action is not correctly registering the script handlers for mapagent.fcgi or *.php, and does not correctly map the mapviewerajax directory.  I haven't tested these yet on the current build of the installer, but I don't think I changed anything that would fix them.
As you test, please enter any defects you find, and also fill in the compatibility chart at:
https://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
Thanks!
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-testing-tp2546428p2547204.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
