[mapguide-internals] RE: Installer testing
Traian Stanev traian.stanev at autodesk.com
Sat Mar 28 15:49:27 EDT 2009
Full success on Vista 32 with Apache/PHP configuration. Very un-clean host machine though...
Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
> internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Friday, March 27, 2009 4:12 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Installer testing
> Hi all,
> I've uploaded a current-ish (last night) version of the open source
> installer with all of the grids (and preliminary version of the two
> raster patches applied) here:
> http://download.osgeo.org/mapguide/testing/
> This hasn't been thoroughly tested yet, so only apply it on test PCs.
> There are still some defects.  The two main ones (I think) are:
> - #930 : Fusion is expecting the web extensions to be installed under
> "webserverextensions".  We're not using that directory by default, and
> are allowing users to modify it during installation.
> - #912 : The IIS7 custom action is not correctly registering the script
> handlers for mapagent.fcgi or *.php, and does not correctly map the
> mapviewerajax directory.  I haven't tested these yet on the current
> build of the installer, but I don't think I changed anything that would
> fix them.
> As you test, please enter any defects you find, and also fill in the
> compatibility chart at:
> https://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
> Thanks!
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
