[mapguide-internals] Installer testing
alucas alucas at svl.es
Sat Mar 28 17:11:37 EDT 2009
I was running the version as you, but like I said, after installation the tomcat service does not start. Maybe you can try to install mapguide with java configuration and then see if your tomcat service starts. If not, you will need to downgrade your jdk version to 1.5.x and compile. It could be important to determine what is the supported versions in order to document it.
Regards.
I think I'm running 1.6.12 (or something like that) on the work PC where I built MapGuide.
Maybe I need to downgrade?  I am Java-clueless.
Jason
________________________________________
Sent: Saturday, March 28, 2009 11:52 AM
Subject: Re: [mapguide-internals] Installer testing
I found another problem with Java version. When I try to preview for example one layer with maestro, I get a java error:
It seems that maybe there is a problem with the jdk version. What JDK version was used to compile the java api? Searching on the net, people say that this problem comes when the jre compiler version is not the same than the running jre version._______________________________________________
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-testing-tp2546428p2550491.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
