[mapguide-internals] RE: PATCH: Raster stability fixes, ticket #462
Traian Stanev traian.stanev at autodesk.com
Sat Mar 28 19:59:22 EDT 2009
Hi Haris,
So if I understand this right, if we disable connection pooling for the GDAL provider, so that every request opens a new FDO connection, which lives for the lifetime of the request, there would be no problem?
I'm not very familiar with the connection pooling stuff, so it's a layman's question.
Traian
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic [haris at sl-king.com]
Sent: Saturday, March 28, 2009 4:42 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: PATCH:  Raster stability fixes,   ticket #462
Regarding MG raster problems ( or any other provider ) the main reason
is connection manager.
If you would set connection pool size 1 , for sdf provider MG will not
work properly.
The patch Jason submitted, is workaround for issue. It will not cause
GDAL to work slower, because provider itself is basically
single-threaded now.
That was done trough work we were doing years or so ago. I was looking
at provider back then and realized that making gdal calls guarded will
make it more stable. Frank then submitted patch with guard on every
single gdal library call.
I will try to explain what is happing now:
1. Map with more than one gdal layer
2. There are two calls in server code execute query and stylize
3. One thread will open connection in execute query and went to stylize
procedure
4. Another thread will come into execute query and because it could be
another layer it will try to open new connection
5. Connection manager will check pool size ( 1 in gdal case ) and
because provider didn't inc. reference count to connection (not  way to
solve, but anyhow provider needs to increment ) it will delete previous
connection and create new one
6. Access violation in first thread while stylization because of deleted
connection
In shorter version things to change:
1. FDO GDAL provider is not increasing reference count on FDO connection
when used in other classes like georasterband , which is later used in
query (wrong)
2. connection manager is managing connection pool by using fdo
connection reference count ( wrong )
3. it looks like working for other providers, because connection pool
size is 200 and other providers are incrementing connection pointer in
select command for example, but if there would be provider with select
command with no reference count to connection, it will crash too
4. Server code is making assumption that pool size for single threaded
is 1 (not correct), we need to make code change to allow for making
calls to provider single threaded
Haris
-----Original Message-----
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Friday, March 27, 2009 4:55 PM
Subject: [mapguide-internals] RE: PATCH: Raster stability fixes, ticket
#462
I totally agree - the locking needs to be in the provider.
Thanks,
Bruce
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, March 27, 2009 9:40 AM
#462
It does look like a sledgehammer approach -- what if some day there is a
raster provider that works ok and doesn't need the locks? If anything,
the lock should be in the FDO provider.
Traian
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Friday, March 27, 2009 11:11 AM
#462
The memory patch (mapguide_raster_unalloc.5.patch) looks good, and I'll
submit that.
The stability patch (mapguide_raster_stability.patch) looks reasonable,
but I'd like another 1 or 2 people to also look at it.  It's significant
since it limits MapGuide to processing one raster stylization request at
a time, but I guess that's better than having a dead lock.  Anyone know
where the thread-unsafe code actually is?  Is it in the provider itself?
Can the mutex be moved closer to the actual thread-unsafe code?
Walt
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Friday, March 27, 2009 3:10 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] PATCH: Raster stability fixes, ticket #462
Haris has been working on the raster stability problem against MapGuide
2.0.2.  I was having the same problems, and was able to duplicate on
2.1.  I have worked with Haris to create patches against trunk that
address a couple of the problems and increase stability immensely.
Could someone please review the patches attached to:
http://trac.osgeo.org/mapguide/ticket/462
and commit them to trunk if appropriate?
My feeling is that the connection management stuff may need some
additional work, since limiting the connection pool to 1 for
single-threaded providers doesn't appear to have the desired effect.
However, getting both of these patches into 2.1 would at least improve
stability for Raster users.
Jason_______________________________________________
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
