[fdo-internals] RE: [mapguide-internals] RE: PATCH: Raster stability fixes, ticket #462
Steve Dang steve.dang at autodesk.com
Sun Mar 29 14:22:24 EDT 2009
I'm not surprised if it is related to some FDO pointer reference counting problems (i.e. all FdoIDisposable derived classes are not thread safe on reference counting). I have run load tests against the Autodesk Raster provider using huge data set before. I will try to load test the GDAL provider when I have a chance.
Thanks,
Steve.
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Sunday, March 29, 2009 11:17 AM
To: MapGuide Internals Mail List
Cc: FDO Internals Mail List
Subject: [fdo-internals] RE: [mapguide-internals] RE: PATCH: Raster     stability fixes, ticket #462
I attached a new patch for the provider to the ticket 462, which speeds up GDAL FDO connection opening by 95%, in addition to the refcounting fix, and the global mutex removal. The global mutex is still needed in two places where I did not disable it.
This change allows you to completely disable MG connection pooling for the GDAL provider (like for SHP and SDF) and still have very good raster speed, since opening a connection is fast now. Also, the global raster mutex can be removed from the MG code.
I will continue testing with this configuration, but so far it looks stable and fast. Obviously it is impossible to prove that a problem no longer exists, when threads are involved, but I will throw some more difficult tests at it -- so far I have only tested with a TIFF-based layer only. The TIFF is 450 megs or so.
Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
> Sent: Sunday, March 29, 2009 1:29 AM
> Subject: RE: [mapguide-internals] RE: PATCH: Raster stability fixes,
> ticket #462
> I attached the patch for the GDAL provider to ticket 462.
> Traian
> > Sent: Sunday, March 29, 2009 1:22 AM
> > ticket #462
> > For what it's worth, patching the provider to addref the parent
> > connection from the feature reader fixes the problem. This is on top
> of
> > Friday's trunk MapGuide and FDO code, without any other extra fixes.
> I
> > do think it is a bug not to addref the connection from the reader,
> when
> > it in fact depends on it to be alive, in order to get stuff from it
> at
> > a later time.
> > I am pretty sure the addref fixes the problem, because the test I am
> > using is fairly brutal and produces the crash/deadlock in less than 5
> > seconds every time I run it with unpatched GDAL provider. With the
> > change, I ran it multiple times to completion.
> > I am unhappy with the fix though, because it leaves CPU usage by
> > mgserver at ~5%, even though I am doing something like 16
> simultaneous
> > requests... So then I decided to remove the global mutex from inside
> > the provider -- that didn't make a difference in CPU usage, and the
> > test still passed without problems. So that mutex can go. Then I
> messed
> > with the connection pooling settings in serverconfig.ini -- those
> > didn't make any difference. I tried them all for the GDAL provider
> and
> > the test still passed with 5% CPU usage. I don't think the process is
> > blocked for I/O because the TIFF I am using is not huge and I also
> > generated an overlay pyramid (which I highly recommend to anyone by
> the
> > way, it makes a huge performance difference for TIFFs).
> > Traian
> > > internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> > > Sent: Saturday, March 28, 2009 4:43 AM
> > > ticket #462
> > > Regarding MG raster problems ( or any other provider ) the main
> > reason
> > > is connection manager.
> > > If you would set connection pool size 1 , for sdf provider MG will
> > not
> > > work properly.
> > > The patch Jason submitted, is workaround for issue. It will not
> cause
> > > GDAL to work slower, because provider itself is basically
> > > single-threaded now.
> > > That was done trough work we were doing years or so ago. I was
> > looking
> > > at provider back then and realized that making gdal calls guarded
> > will
> > > make it more stable. Frank then submitted patch with guard on every
> > > single gdal library call.
> > > I will try to explain what is happing now:
> > > 1. Map with more than one gdal layer
> > > 2. There are two calls in server code execute query and stylize 3.
> > One
> > > thread will open connection in execute query and went to stylize
> > > procedure 4. Another thread will come into execute query and
> because
> > > it could be another layer it will try to open new connection 5.
> > > Connection manager will check pool size ( 1 in gdal case ) and
> > because
> > > provider didn't inc. reference count to connection (not  way to
> solve,
> > > but anyhow provider needs to increment ) it will delete previous
> > > connection and create new one 6. Access violation in first thread
> > > while stylization because of deleted connection
> > > In shorter version things to change:
> > > 1. FDO GDAL provider is not increasing reference count on FDO
> > > connection when used in other classes like georasterband , which is
> > > later used in query (wrong) 2. connection manager is managing
> > > connection pool by using fdo connection reference count ( wrong ) 3.
> > > it looks like working for other providers, because connection pool
> > > size is 200 and other providers are incrementing connection pointer
> > in
> > > select command for example, but if there would be provider with
> > select
> > > command with no reference count to connection, it will crash too 4.
> > > Server code is making assumption that pool size for single threaded
> > is
> > > 1 (not correct), we need to make code change to allow for making
> > calls
> > > to provider single threaded
> > > Haris
> > > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> > Bruce
> > > Dechant
> > > Sent: Friday, March 27, 2009 4:55 PM
> > > Subject: [mapguide-internals] RE: PATCH: Raster stability fixes,
> > > ticket
> > > #462
> > > I totally agree - the locking needs to be in the provider.
> > > Thanks,
> > > Bruce
> > > Traian Stanev
> > > Sent: Friday, March 27, 2009 9:40 AM
> > > ticket
> > > #462
> > > It does look like a sledgehammer approach -- what if some day there
> > is
> > > a raster provider that works ok and doesn't need the locks? If
> > > anything, the lock should be in the FDO provider.
> > > Traian
> Walt
> > > Welton-Lair
> > > Sent: Friday, March 27, 2009 11:11 AM
> > > ticket
> > > #462
> > > The memory patch (mapguide_raster_unalloc.5.patch) looks good, and
> > > I'll submit that.
> > > The stability patch (mapguide_raster_stability.patch) looks
> > > reasonable, but I'd like another 1 or 2 people to also look at it.
> > > It's significant since it limits MapGuide to processing one raster
> > > stylization request at a time, but I guess that's better than
> having
> > a
> > > dead lock.  Anyone know where the thread-unsafe code actually is?
> Is
> > > it in the provider itself?
> > > Can the mutex be moved closer to the actual thread-unsafe code?
> > > Walt
> > Jason
> > > Birch
> > > Sent: Friday, March 27, 2009 3:10 AM
> > > To: mapguide-internals at lists.osgeo.org
> > > Subject: [mapguide-internals] PATCH: Raster stability fixes, ticket
> > > #462
> > > Hi,
> > > Haris has been working on the raster stability problem against
> > > MapGuide 2.0.2.  I was having the same problems, and was able to
> > > duplicate on 2.1.  I have worked with Haris to create patches
> against
> > > trunk that address a couple of the problems and increase stability
> > immensely.
> > > Could someone please review the patches attached to:
> > > http://trac.osgeo.org/mapguide/ticket/462
> > > and commit them to trunk if appropriate?
> > > My feeling is that the connection management stuff may need some
> > > additional work, since limiting the connection pool to 1 for
> > > single-threaded providers doesn't appear to have the desired effect.
> > > However, getting both of these patches into 2.1 would at least
> > improve
> > > stability for Raster users.
> > > Jason_______________________________________________
> > > mapguide-internals mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the mapguide-internals mailing list
