[mapguide-internals] Build Server - which??
UV uvwild at gmail.com
Mon Mar 30 07:38:32 EDT 2009
I found this list for the interested....
http://stackoverflow.com/questions/145586/what-continous-integration-tool-is-best-for-a-c-project
Trevor Wekel wrote:
> Hi UV,
> Cruise control is an excellent option.  I was also looking into Buildbot.  I believe Buildbot may be better suited to performing simultaneous multi-platform builds since it has a master/slave model.  http://buildbot.net/trac
> Thanks,
> Trevor
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV [uvwild at gmail.com]
> Sent: Thursday, March 26, 2009 7:56 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Build Server - CruiseControl?
> Hello,
> I had a lock at the build server and I am offering to set up cruise
> control NET on this machine to run builds and show which build numbers
> succeeded.
> I have been using this previously in a distributed project team and I
> believe CI is pretty much the state of the art.
> (Why cruisecontrol? Its mature and sourceforged and I know it so I can
> set it up!)
> Cruisecontrol can be tuned in terms of the conditions when to run the build.
> The results of those builds are available on a dashboard page on a web
> server and as a tray icon on the users machine. (needs an open port)
> Furthermore I can imagine an upload page which could be used to upload a
> patch to the server thereby triggering
> the checkout of the last revision, applying the patch and running a
> build thereafter, reporting the results to the dashboard.
> Any Comments?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals_______________________________________________
More information about the mapguide-internals mailing list
