[mapguide-internals] Installation directory structure
Jason Birch Jason.Birch at nanaimo.ca
Mon Mar 30 23:49:41 EDT 2009
Quick note:  Agreed, but would prefer "MapGuide", without version number in path.  And really, really, want to see data dir locations (logs, repos, packages, temp) remain configurable at install time.
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Mon Mar 30 19:21:38 2009
Subject: [mapguide-internals] Installation directory structure
Hi All,
There seems to be some talk that the current directory structure used by the installer is not quite ideal. If so, then what should the ideal structure be?
I would prefer something like:
$INSTALLDIR = C:\Program Files\OSGeo\MapGuideOpenSource
$INSTALLDIR\Server
$INSTALLDIR\WebServerExtensions
$INSTALLDIR\CSMap
This would be like the structure of previous releases, except by default it goes under the 'OSGeo' name and it will work-around the fusion having hard-coded the web server extension path. Jason suggested locking down the Server and Webextension directories which I think is a good idea. The less number of configurable paths, the better.
Thoughts?
- Jackie
P.S. I didn't come up with the initial directory structure. I just went with the flow :-)
View this message in context: http://n2.nabble.com/Installation-directory-structure-tp2560810p2560810.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
