[mapguide-internals] Is 2.1 going to support 64-bit
Bruce Dechant bruce.dechant at autodesk.com
Tue Mar 31 11:39:28 EDT 2009
Helio,
Did you get it working on Windows with 5.4? Reason I ask is that when I built with ACE 5.4 for Windows the IP address was switched, ie: 144.111.1.2 would end up being transposed into 2.1.111.144. If I entered the IP address backwards in the webconfig.ini it worked. When I upgraded to ACE 5.6 this bug went away on Windows.
What issues are you seeing with dbxml? I have been using 64bit server on Windows for several days now without issue.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Monday, March 30, 2009 5:43 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Is 2.1 going to support 64-bit
On Segunda-feira 30 Março 2009, Bruce Dechant wrote:
> Zac,
> 2.1 won't support 64bit as it requires a switch to ACE5.6. We are currently
> on ACE5.4. The plan is to update to ACE5.6 after 2.1 is released as we
> don't want to destabilize 2.1 by switching ACE versions this close to
> release.
> Thanks,
> Bruce
ACE indeed is not an issue, since i already did a 64 bit compilation, working.
The real issue is dbxml, which can't be upgraded from the internal one and any
small minor version change on the base db cause the most unusual crashes.
64 bits in linux is doable, but requires a little effort and i don't think
would be possible for a mapguide release
KDE Developer
Brasil/South America Primary Contact
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
