[mapguide-internals] Commit rights for UV
UV uvwild at gmail.com
Thu May 7 22:27:39 EDT 2009
Currently, the process is only poorly defined and does not state very
clear rules in particular in regards of timing.
Can someone jump in (from the PSC i guess) review my code and provide me
some feedback, I've been working on this for a while now and I would
like to know how close I am to getting commit rights?
The several patches requirement is a little loose, as for RFC60 there is
one big patch, which could be seen as a equivalent to several smaller
patches? And there are other contributions regarding other issues which
show further insight into the server code.
Zac Spitzer wrote:
> Just been reading the PSC notes, sorry I couldn't make the session,
> waaayy to late down under..
> I am rather worried about the trend that UV after posting a RFC
> and then actually implementing it, plus his work on the build stuff
> plus numerous other small issues he delved into and has found
> solutions for, still isn't being considered for commit rights as
> per the notes from the PSC...
> How high is the barrier for entry? Where are the PSC members
> actively supporting new developers and guiding them into moving
> forward to commit status.
> This seems to of happened with both Helio and UV, both have stepped
> up, dived deep into the code base but are still 'locked out'
> I think the PSC needs to be way more active in this regard if MapGuide is
> going to succeed as an open source project.
> Initially with UV, the feedback from the Autodesk team was that they
> where reluctant to guide new developers until they proved their commitment.
> There is a certain level of irony in the PSC notes, where on one hand it
> has been said that UV is not ready for commit rights, but at the same time, he
> has done the work on working out failed tiled stuff which was no minor effort
> in itself and the PSC then suggesting that he should write a RFC for it..
> That seems rather contradictory.
> Moving forward, can I ask for someone in the PSC take a direct involvement
> in regards to commit rights for UV?
> z
More information about the mapguide-internals mailing list
