[mapguide-internals] MGOS 2.1 branch
Tom Fukushima tom.fukushima at autodesk.com
Sun May 10 23:23:58 EDT 2009
If no one finds a problem with it, I would like to put Installer, MgDev and Tools into the 2.1 branch.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, May 08, 2009 1:40 PM
To: 'mapguide-internals at lists.osgeo.org'
Subject: Re: [mapguide-internals] MGOS 2.1 branch
No real concerns with this, but would love to see Trevor's upcoming fixes make it into the 2.1 branch.
Should we move the installer code inside of mgdev so it comes along for the ride with branches/tags, or should we branch/tag seperately?
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Thu May 07 14:36:02 2009
Subject: [mapguide-internals] MGOS 2.1 branch
There is some work in the CsMap trunk that is going to get underway and will require some changes to MGOS.  The changes should not go into MGOS 2.1 because they require large changes, so I would like to create the MGOS 2.1 branch on the week of May 18th.
After the branch the difference between Trunk and the 2.1 branch will be that branch will (continue to) point to CsMap branch 12.01, and trunk will point to CsMap trunk.
Any questions or concerns?
Thanks
Tom
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
