[mapguide-internals] Another installer test...
Simon Pelicon
simon at sl-king.com
Mon May 11 03:51:46 EDT 2009
Hi!
I successfully installed MapGuide 2.1 with this installer (Using IIS and
PHP) without any problem. Good job.
I noticed some minor issues. Initial file unpacking files was a bit slow and
i think that calculated disk usage was wrong (it required 1.4 GB of disk )
Simon
Jackie Ng wrote:
I mean Apache.
- Jackie
Jackie Ng wrote:
The PHP side is still good (nothing broken). I think we're on a winner
here.
- Jackie
Jason Birch wrote:
Hi all,
I've uploaded a new installer for testing.
[1]http://download.osgeo.org/mapguide/testing
Make sure that you grab 0.6 or later!
This required some pretty serious retrofitting, especially to get the IIS
5.1 and IIS 6 installs to work, but I've had a fair amount of success in
my testing. I got good results with:
- XP
- Apache + Java
- IIS + DotNet
- IIS + PHP
- Windows 2003
- IIS + DotNet
- IIS + PHP
- Windows 2008
- IIS + DotNet
If you see a configuration that you can test, please let us know by
updating the Installer Status wiki and entering any defects:
[2]http://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
[3]http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Thanks,
Jason
mapguide-internals mailing list
[4]mapguide-internals at lists.osgeo.org
[5]http://lists.osgeo.org/mailman/listinfo/mapguide-internals
References
1. http://download.osgeo.org/mapguide/testing
2. http://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
3. http://trac.osgeo.org/mapguide/wiki/SubmitTicket
4. mailto:mapguide-internals at lists.osgeo.org
5. http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
