[mapguide-internals] RE: Another installer test...
Jason Birch Jason.Birch at nanaimo.ca
Wed May 13 09:33:51 EDT 2009
That's interesting...
Is your main site set up that way too?
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Wed May 13 00:46:06 2009
Subject: Re: [mapguide-internals] RE: Another installer test...
After installing on Win 2K3 R2, with IIS ASP.Net,
the mapagent has "integrated authentication" enabled, which causes all
requests to be denied (authentication failed).
I'm not sure why that is enabled, or if its fixable in the installer.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Oh...
> I forgot to say that this build also includes:
> - Trevor's recent fixes for the HTTP connection
> - Bruce's fixes for the fdo connection problems (mostly evident in GDAL)
> - Walt's optional optimizations for dealing with thick lines
> Lots of goodies in there to look at when you get a successful install.  If you've been having stability problems, this is definitely worth trying out.
> Jason
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
